Benchtop Small Plastic Buffing Kit
Now you can easily buff scratches and haze from plastics including CD's, eyeglass lenses, plastic auto moldings, and much more.
First, buff the part with the heavy cutting buffing compound (white) and the loose cotton wheel.
Finally, buff with the blue compound and a Canton Flannel wheel. This wheel is extremely soft and will produce a brilliant shine.
The buffing rake enables you to keep the wheels clean.
Kit contains:
- 1 x 1/3hp buffing machine
- 4 x 6" Loose Cotton wheels
- 4 x 6" Canton Flannel wheels
- 1 x buffing rake
- 2 large bars Blue Buffing Compound
- 2 large bars White Buffing Compound
