Mid Speed 1100RPM Buffers are ideal for polishing straight razors.
The kits include all the wheels and buffing compound you will need to polish straight razors in three buffing steps, starting with black compound, then green, then white.
The Advanced Kit also includes a blue compound for extra fine buffing, and greaseless compounds for more precision polishing.
A wheel rake is included to clean the wheels.
Stands for the buffers are also available.
Basic Kit includes:
- 1100RPM, 3/4HP Buffer
- 2 x 4" Spiral Sewn Cotton Wheels
- 2 x 4" Loose Cotton Wheels
- 2 x 6" Spiral Sewn Cotton Wheels
- 2 x 6" Loose Cotton Wheels
- Black, Stainless and White Compounds (Large Size)
- Wheel Rake
- Instructions
Recommended Skill Level
Beginner level products can and should be used by anybody, including those who consider themselves not crafty, handy or hands on. Most beginner level products can be used out of the box and can expect results within minutes. It is always important to read the product instructions and description on the web site before use, for example, nearly all of our plating kits require a polished and clean surface before plating.
