null
Get Our Booklet
Polishing
Download our FREE How To Buff & Polish Booklet and learn how to use these products.
  • TAPERED BUFFING SPINDLE 5/8" LEFT
    Tapered Buffing Spindles are ideal for mounting buffing wheels with pinhole centers, such as our Razor Buff. Simply attach the spindle onto your 1/2" or 5/8" shaft, tighten the grub screws, and the spin the motor up. The buffing wheel is pushed onto the...
    $19.79
    Add to Cart
  • TAPERED BUFFING SPINDLE 5/8" RIGHT
    $19.79
    Add to Cart
  • TREATED RAZOR BUFF - 6"
    1/8" thick treated, razor buffs are perfect for getting into tight work areas and between fins on cylinder heads. The treated material is tough, long lasting and flexible. Use with a cutting compound. Buffs feature leather reinforced centers, with half...
    $4.94
    Add to Cart
  • TREATED RAZOR BUFF - 8"
    1/8" thick treated, razor buffs are perfect for getting into tight work areas and between fins on cylinder heads. The treated material is tough, long lasting and flexible. Use with a cutting compound. Buffs feature leather reinforced centers, with...
    $6.04
    Add to Cart
  • TREATED SPIRAL SEWN BUFFING WHEEL - 4
    These buffs are specially treated to give longer life than standard buffs. This treatment makes them much harder than regular cotton buffs, which allows the user to exert more pressure onto the wheel and gets the job done faster. Use with any compound...
    $9.99
    Choose Options
  • TREATED SPIRAL SEWN BUFFING WHEEL - 6
    $9.89
    Choose Options
  • TREATED VENTED BUFFING WHEEL - 4
    These buffs are specially treated to give longer life than standard buffs. They cut and color faster and are vented to keep the workpiece cooler. Hard center allows fast mounting to tapered spindel for quick change. Use with any compound.
    $8.79
    Choose Options
  • TREATED VENTED BUFFING WHEEL - 6" X 1/2"
    $9.89
    Choose Options
  • TREATED VENTED BUFFING WHEEL - 8
    $12.09
    Choose Options
  • UNTREATED VENTED BUFFING WHEEL - 6
    The folded pleats hold more compound and keep the part cooler, resulting in a being twice as fast as a Spiral Sewn wheel. 10" wheels require 3" washers. These wheels are softer than their yellow cousins.
    $8.79
    Add to Cart
  • VIBRATORY TUMBLER - ADJUSTA-VIBE 18
    Heavy duty & adjustable for all medias The AV-18 has capacity of .18 cubic feet (5.3 Quarts). It has adjustable amplitude and is designed for heavy duty use with all medias. The 12-inch bowl is equipped with drains. This model has many features of our...
    $544.50
    Add to Cart
  • VIBRATORY TUMBLER - ADJUSTA-VIBE 40
    Compact with adjustable amplitude Model 40 vibratory machines are compact, yet have a capacity of .35 cubic feet (10.4 quarts) and are equipped with amplitude adjustment, inlet and outlet ports for compound rinsing systems and heavy duty cross-linked...
    $1,287.00
    Add to Cart
