These buffs are specially treated to give longer life than standard buffs. This treatment makes them much harder than regular cotton buffs, which allows the user to exert more pressure onto the wheel and gets the job done faster. Use with any compound just like standard spiral sewn wheels.
best wheel so far
I'm a relative novice at buffing (straight razors). Of all the kinds of wheels I've tried, this is the best so far. It gives a nice stiff surface to buff against with a light touch. It holds up well. And it doesn't overheat too easily. Good product.
