TREATED RAZOR BUFF - 6"
1/8" thick treated, razor buffs are perfect for getting into tight work areas and between fins on cylinder heads. The treated material is tough, long lasting and flexible. Use with a cutting compound. Buffs feature leather reinforced centers, with half inch holes (not pictured above)
4 Reviews Hide Reviews Show Reviews
quality products help the job get done
I needed a very thin buff to get between the fins on my motor. This worked well. Sound have ordered two
Great wheel
Great for that cutting edge you need, I use on brass
When you need one
This was purchased just in case I needed one. Saved a lot of time when the right job came along.
