TREATED RAZOR BUFF - 8"
1/8" thick treated, razor buffs are perfect for getting into tight work areas and between fins on cylinder heads. The treated material is tough, long lasting and flexible. Use with a cutting compound. Buffs feature leather reinforced centers, with pinholes. Can be punched to ½" hole. Select option below.
good
nice
