UNTREATED VENTED BUFFING WHEEL - 10
The folded pleats hold more compound and keep the part cooler, resulting in a being twice as fast as a Spiral Sewn wheel. 10" wheels require 3" washers. These wheels are softer than their yellow cousins.
White Buffs
Great For Coloring
