TAPERED BUFFING SPINDLE 5/8" LEFT
Tapered Buffing Spindles are ideal for mounting buffing wheels with pinhole centers, such as our Razor Buff. Simply attach the spindle onto your 1/2" or 5/8" shaft, tighten the grub screws, and the spin the motor up.
The buffing wheel is pushed onto the end of the spindle, and is quickly drawn onto the spindle.
Use right hand spindles for the right side of your buffer (counter clockwise rotation). Use left hand spindles for the left side of your buffer (clockwise rotation).
