Anodize Touch Up Kit
Repair Scratched or Damaged Black Anodize
 Kit Contains:
- 4 oz Anodize Touch Up Liquid
- 4 oz Cleaning Solution
- 4 oz Sealing Solution
- Protective Gloves
- Cotton Swabs
- Instructions
Our Anodize Touch Up Kit is ideal for repairing scratched or damaged black anodized parts. Simply clean, repair and seal. No fumes, no heating required. Parts are repaired in minutes.
Save thousands over stripping and re-anodizing damaged parts. Much better than using a black marker or paint, the solution chemically converts the aluminum into a black color with a permanent repair. Won't chip, peel or rub off.
                Recommended Skill Level
                    Beginner level products can and should be used by anybody, including those who consider themselves not crafty, handy or hands on. Most beginner level products can be used out of the box and can expect results within minutes. It is always important to read the product instructions and description on the web site before use, for example, nearly all of our plating kits require a polished and clean surface before plating.
Hazardous Shipping Info
  			 GHS Info
			 SDS
