These professional quality anodizing dyes provide consistent, quality results. The same dyes are sold to professional anodizing shops all over the world. 4oz of dye concentrate makes 2 Gallons.
These colors are approximate. The finish will normally have a more 'metallic' look, and will vary slightly depending on the alloy and surface preparation.
Procedure for Obtaining Dyed Anodize
Anodize the aluminum at 60-75°F for 90 minutes at 4.5 amps per sq foot or 0.03 amps per sq inch. Use our Anodizing Kit.
After thorough rinsing, immerse the part in the dye at a temperature of 140°F for 15 minutes.
Finally, seal by hanging the part in a sealer bath for 15 minutes.
All dyes are fully ROHS compliant.
GHS Info
SDS
7 Reviews Hide Reviews Show Reviews
Great
Thank you!
good quilty color
practice on test samples first. good color, will get to orange if left to long > timing is the key<, test timing a must!
Excellent, very easy to use and beautiful uniform color.
I am a first time user and very satisfied with this product. The result is excellent, it's very easy to use and the color is beautifully uniform. Great.
it's gold
I've never been impressed with how well this absorbs into the parts. It takes a very long time and it does have to be very hot in order to absorb.
Good as Gold
My neighbor wanted to anodize a piece of ,125" aluminum (type unknown) and dye it gold. De-smut had little or no reaction. The anodizing went without a hitch. I immersed the part in the warm dye and the piece started to take on color almost immediately. I pulled it after about 12 minutes. It was a bit darker than I wanted and realized I should have pulled it earlier but he was elated at the outcome. I steam sealed the part and gave it a coat of lacquer. Beautiful ! Highly recommended.
Not bad
This dye is gold. what more do you expect. You get what you want. Works well if a little slow for me. I've also used it for a yellow.
Excellent !
Le résultat est superbe . Mais il dépend de votre préparation . Pour ma part, j'ai re-dilué une seconde fois la teinture avec 100% d'eau distillée pour un résultat parfait . Sur une pièce polie, on dirai vraiment de l'or !
