These professional quality anodizing dyes provide consistent, quality results. The same dyes are sold to professional anodizing shops all over the world. 4oz of dye concentrate makes 2 Gallons.
These colors are approximate. The finish will normally have a more 'metallic' look, and will vary slightly depending on the alloy and surface preparation.
Procedure for Obtaining Dyed Anodize
Anodize the aluminum at 60-75°F for 90 minutes at 4.5 amps per sq foot or 0.03 amps per sq inch. Use our Anodizing Kit.
After thorough rinsing, immerse the part in the dye at a temperature of 140°F for 15 minutes.
Finally, seal by hanging the part in a sealer bath for 15 minutes.
All dyes are fully ROHS compliant.
GHS Info
SDS
3 Reviews Hide Reviews Show Reviews
great blue
Color takes fast and very rich in color
Excellent, very easy to use and beautiful uniform color.
I am a first time user and very satisfied with this product. The result is excellent, it's very easy to use and the color is beautifully uniform. Great.
Good Blue, just as I expected
I found this easy to use. When used as instructed it produced very good consistent results. Very happy with the results.
