2 fl oz bottle
Add One Teaspoon fume suppressant to a 5 gallon anodizing bath.
Each 2oz bottle contains 10 doses.
Re-dose when fumes are detected. DO NOT OVERDOSE.
![This product can ship air and worldwide This product can ship air and worldwide](/content/images/airok.png)
SDS
5 Reviews Hide Reviews Show Reviews
My mistake
I read the label incorrectly. It states 2 tsp. per 4 gallons of made up anodizing solution and not the entire bottle for 4 gallons as I originally interpreted.
Anodize fume suppressant
The Caswell Anodizing fume suppressant works real well , before adding the supperesant the mist was unbareable without proper PPE.
Great Safety Item
Works when used as suggested... Reduces fumes around plating area... Reduces corrosion on copper and other metal plating tank bar...
Worth it
Was debating on getting this, after first use in was very happy we decided to purchase this! Shop is ventilated during winter but not as open, makes a very noticeable difference
Helpful item
This is very helpful when working in the winter months with the shop closed up.
