These professional quality anodizing dyes provide consistent, quality results. The same dyes are sold to professional anodizing shops all over the world. 4oz of dye concentrate makes 2 Gallons.
These colors are approximate. The finish will normally have a more 'metallic' look, and will vary slightly depending on the alloy and surface preparation.
Procedure for Obtaining Dyed Anodize
Anodize the aluminum at 60-75°F for 90 minutes at 4.5 amps per sq foot or 0.03 amps per sq inch. Use our Anodizing Kit.
After thorough rinsing, immerse the part in the dye at a temperature of 140°F for 15 minutes.
Finally, seal by hanging the part in a sealer bath for 15 minutes.
All dyes are fully ROHS compliant.
GHS Info
SDS
24 Reviews Hide Reviews Show Reviews
I have used The black Caswell Dye on all my Silencers and it's amazing.
The black Caswell dye has always performs well over the past year for me. I have anodized many parts and it is still great without dong anything. I have tried powder forms of dyes and have nad no luck with them. It was also ver hard to mix the other powder dyes. Caswell liquid dye mixs perfectly and effortlessly every time. Thanks Caswell for making my anodizing a huge success. Also the free red you gave me looked amazing.
Very good product!!!
The Black HBL Anodize Dye from casswell has to be one of the best Dyes on the planet. Very black and always looks great.
Intense black
Intensity of this black is extreme. Beware various types of aluminum will dye differently, I'm working with 5000 series and it works great.
caswell is awesome
I've anodized more than 20 80%'ers with one of these.
Great experience start to finish
Not only was the black ano dye a perfect performer, but the tech support provided was awesome. Definitely going to return to Caswell the next time I need supplies.
nice product
great quality
GOOD STAFF
GOOD STAFF
As described
Arrived in 2 days
Pricey, but works fine...
I'm still not sure why black anodizing dye is so much more expensive than other colors. I was also a little surprised to receive the dye in liquid form. Other colors I have bought - not from Caswell - were in powder form, so they were a little easier to divide for 1 gallon mixes.
Caswell Reply - Black is a mixture of many primary colors and is much more expensive to manufacture.
