Nickel Acetate based sealer. Use at the rate of 1 oz to 1 gal of water. This 1 lb bag makes 16 gallons. Bath life is 14-60 days, depending on use. Heat to 210 deg F, and seal for 5-30 minutes.
GHS Info
			 SDS
24 Reviews Hide Reviews Show Reviews
                AmazingWorks much better than boiling water alone
                Sealed fast no color lossFor any one who has been boiling water to seal, I have to tell you make the choice to buy this product. The seal works great doesnt dilute your color. I personally never had a problem with powder like residue. However make sure you have a fume hood or well ventilated area. When the solution reaches temp it gives off a strong odor. Be safe
                Great stuff!I was using boiling water to seal my anodized projects, but was having significant problems with the dyes leaching out during the sealing process. I read about nickel acetate and decided to give this a try. I'm glad I did! It sealed very nicely without letting any dye escape. There's a fine powdery residue left on areas of the pieces after sealing, but it can be wiped off with a damp cloth.
                Thank you for the fast deliveryThank you Caswell for your prompt delivery and exelent choices of anodizing colors and products .
                Awsome sealantEasy to follow instructions and a snap to use.
                Fast, even sealingA simple product that cuts the time and increases the durability and colorfastness of the anodized article. A little goes a long way.
                outstanding product and service.I received the sealant quickly. The sealant works great. Very happy with this purchase
                niceworks well
                As describedArrived in 2 days
