"General Purpose" plates. Ideal for larger anodizing systems (use as cathodes), or stripping tanks. Lead sheet is 1/32" thick. Can also be used as an anode when chrome plating.![This product can ship air and worldwide This product can ship air and worldwide](/content/images/airok.png)
9 Reviews Hide Reviews Show Reviews
nice product
great quality
works well
good QUILTY
As described
Arrived in 2 days
Perfect!
Perfect sheet to cut up into whatever sized plates you need! Thanks
Good product
Works great and is easy to use
Thanks for the prompt service
EXCELLENT seller which is why I continue to buy from!!!
Great plates
These plates work great for for the 5 gallon buckets.
Does what you need it to do
These lead plates are excellent for the smallish plating and deplating jobs I do. Can't go wrong!
great product, I would buy again
worked out good for my smaller snooping project s just wish they sold them in larger
