1 Quart mixes with 2 gallons of water. Use to minimize smutting of aluminum parts before anodizing or plating. Use at 70-110 deg F, for 1-3 minutes.
Hazardous Shipping Info
GHS Info
SDS
23 Reviews Hide Reviews Show Reviews
A MUST Have
Keeps your parts clean and ready. It has saved many hours and parts.
Deoxidizer/Desmut
I have tried many different mixes of Deoxidizer/Desmut. But I always end you back at Caswell. Their products are always Top Notch.
Keep up the good work. -
Worked Great!
I used it on my Forged lower for an AR. It did a good job cleaning up all the other metals left after my caustic bath etched the Aluminum away.
Great
Thank you!
Deoxidizer / Desmut
The deodorizer / desmut solution gives the anodizing a great foundation & finish to final seal.
Deoxidizer/Desmut
I worked great and did exactly as advertised
Deoxidizer/Desmut
Must Have
Works great! If your serious about getting consistent results, this is a must have product. De-oxidizer ensures a perfectly clean part to start with. Cleans heavy smut off fast.
As described
Arrived in 2 days
