Cyclone Parts Dryer
Blackening Parts? Need Fast Part Drying?
The Cyclone Parts Dryer speeds up the drying process, helps prevent flash rusting and dries without water spots
Features
- 11” x 10” x 13”
- One inch tray depth
- 3 hour timer
- Recessed handles on trays for easy loading and unloading
- Fast drying time (approx one hour)
- Works with any parts
- Also perfect for drying brass cases after cleaning - Holds up to 1000 – 223 cases or 2000 – 9mm cases
