Chocolate Brown
Produces a chocolate brown to antique brown finish on copper and brass. Mix 15% concentrate with 85% water. Use as a dip at room temperature.
Recommended Skill Level
Beginner level products can and should be used by anybody, including those who consider themselves not crafty, handy or hands on. Most beginner level products can be used out of the box and can expect results within minutes. It is always important to read the product instructions and description on the web site before use, for example, nearly all of our plating kits require a polished and clean surface before plating.
Hazardous Shipping Info
GHS Info
SDS
