ZINC BLACKENER - 1 PINT
Zinc Blackener A360
A room temperature blackening process for die cast and plated zinc surfaces. The very mild acidic liquid concentrate is diluted with 9 parts of water for a 10% by volume working solution. Immersion times of 2 - 5 minutes. Equally effective on cadmium surfaces.
Hazardous Shipping Info
GHS Info
SDS
