Tiffany Green
The original solution for the €˜greening' of the copper components of Tiffany lamps. Apply the solution, undiluted, with a soft paintbrush. Allow to react on the copper overnight.
Recommended Skill Level
Beginner level products can and should be used by anybody, including those who consider themselves not crafty, handy or hands on. Most beginner level products can be used out of the box and can expect results within minutes. It is always important to read the product instructions and description on the web site before use, for example, nearly all of our plating kits require a polished and clean surface before plating.
Hazardous Shipping Info
GHS Info
SDS
