BLACK & BROWN OXIDIZER
Black & Brown Oxidizer
Blackens silver and nickel and browns copper and brass. Mix 15% concentrate with 85% water. Use as a dip at room temperature.
Hazardous Shipping Info
GHS Info
SDS
