Flemish Grey & Blackener 16 fl oz
For use on copper, brass and bronze. 15% to 20% by volume solutions produce black to blackish-brown US 10B (Oil Rubbed) finishes on copper and brass with immersions of 1 to 3 minutes. Diluted 5% to 10% by volume solutions produce lighter flemish and statuary bronzes with 1 to 3 minutes of immersion. Desirable underlying red tones revealed upon highlighting the brown tones.
Hazardous Shipping Info
GHS Info
