null
We Are Moving - New Address is 117 Victor Heights Pkwy, Victor NY 14564
Your patience is appreciated as we unpack and setup
Category Name: Wet
  • 1000 GRIT WET AND DRY PAPER
    Silicon Carbide Wet & Dry Paper gives you exceptionally long life with increased cutting power. Use before buffing compound to remove deep scratches, sand casting marks and more. Order packs of 100 to save!
    $0.54
    Add to Cart
  • 120 GRIT WET AND DRY PAPER
    $0.54
    Add to Cart
  • 1200 GRIT WET AND DRY PAPER
    Aluminum Oxide Wet & Dry Paper gives you exceptionally long life with increased cutting power. Use before buffing compound to remove deep scratches, sand casting marks and more. Order by the individual sheet, or by the 100 sheet pack.
    $0.54
    Add to Cart
  • 1500 GRIT WET AND DRY PAPER
    $0.54
    Add to Cart
  • 2000 GRIT WET AND DRY PAPER
    $1.64
    Add to Cart
  • 240 GRIT WET AND DRY PAPER
    $0.54
    Add to Cart
  • 2500 GRIT WET AND DRY PAPER
    $1.09
    Add to Cart
  • 3000 GRIT WET AND DRY PAPER
    $1.09
    Add to Cart
  • 320 GRIT WET AND DRY PAPER
    $0.54
    Add to Cart
  • 360 GRIT WET AND DRY PAPER
    $0.54
    Add to Cart
  • 400 GRIT WET AND DRY PAPER
    $0.54
    Add to Cart
  • 60 GRIT WET AND DRY PAPER
    $0.54
    Add to Cart
  • 80 GRIT WET AND DRY PAPER
    $0.54
    Add to Cart
