2000 GRIT WET AND DRY PAPER
Silicon Carbide Wet & Dry Paper gives you exceptionally long life with increased cutting power. Use before buffing compound to remove deep scratches, sand casting marks and more. Order packs of 100 to save!
5 Reviews Hide Reviews Show Reviews
GREAT PRODUCT GREAT FOR FINISHING STAINLESS STEEL
Good to have around in the shop!
Great sandpaper use this for the final polishing of watches!
Sandpaper is cost effective. Love this product........Buff and polish watches THIS GRADE IS FANTASTIC FOR THE FINAL FINISH.....
My favorite supply site great polish stuff
Another Excellent product
better than 3M
Though sand paper was sand paper but this last siginficantly longer than 3M. leaves a nice even finish too.
Great value
wonderful wet/dry abrasive for wood work
