2500 GRIT WET AND DRY PAPER
Silicon Carbide Wet & Dry Paper gives you exceptionally long life with increased cutting power. Use before buffing compound to remove deep scratches, sand casting marks and more. Order packs of 100 to save!
better than 3M
Though sand paper was sand paper but this last siginficantly longer than 3M. leaves a nice even finish too.
Incredible value
wonderful wet/dry abrasive for wood work
