Silicon Carbide Wet & Dry Paper gives you exceptionally long life with increased cutting power. Use before buffing compound to remove deep scratches, sand casting marks and more. Order packs of 100 to save!
3 Reviews Hide Reviews Show Reviews
Great
Great
Great value
wonderful wet/dry abrasive for wood work
Excellent purchasing experience.
As always, great prices... prompt shipment... quality products. Will definitely order from again.
