1500 GRIT WET AND DRY PAPER
Silicon Carbide Wet & Dry Paper gives you exceptionally long life with increased cutting power. Use before buffing compound to remove deep scratches, sand casting marks and more. Order packs of 100 to save!
5 Reviews Hide Reviews Show Reviews
Great product!
better than 3M
Though sand paper was sand paper but this last siginficantly longer than 3M. leaves a nice even finish too.
Replacement Paper
Quality paper.
Great value
wonderful wet/dry abrasive for wood work
Great Product
I purchased this sandpaper in multiple grits to sand down the finish on a guitar neck. The sheets are very large and provided a lot of strips for my purposes.
