360 GRIT WET AND DRY PAPER
Silicon Carbide Wet & Dry Paper gives you exceptionally long life with increased cutting power. Use before buffing compound to remove deep scratches, sand casting marks and more. Order packs of 100 to save!
Great deal
Good general purpose, I like the fact that I can buy it by the sheet and get a discount for multiples
Great value
wonderful wet/dry abrasive for wood work
