80 GRIT WET AND DRY PAPER
Aluminum Oxide Wet & Dry Paper gives you exceptionally long life with increased cutting power. Use before buffing compound to remove deep scratches, sand casting marks and more. Order by the individual sheet, or by the 100 sheet pack.
good product.
fast shipping,and good prices
