Silicon Carbide Wet & Dry Paper gives you exceptionally long life with increased cutting power. Use before buffing compound to remove deep scratches, sand casting marks and more. Order packs of 100 to save!
7 Reviews Hide Reviews Show Reviews
Great
Great price.
Quality abrasive
Very good quality sandpaper. Great price.
Great product!
better than 3M
Though sand paper was sand paper but this last siginficantly longer than 3M. leaves a nice even finish too.
Great value
wonderful wet/dry abrasive for wood work
Excellent for wood finishing also
For over four years, I have been using these wet/dry sheets in grades from 320 to 3000 grit to prepare my woodwork products for finishing. The smoother the wood before finishing, the smoother the final finish. I can actually see the reflection of my hand holding 1000+ grit sandpaper while final sanding a hardwood pen or bowl on a lathe. Great product, doesn't clog easily, excellent price compared to local purchase. Actually wet/dry grits over 1000 are not very available in local retail markets.
Great Product
I purchased this sandpaper in multiple grits to sand down the finish on a guitar neck. The sheets are very large and provided a lot of strips for my purposes.
