1200 GRIT WET AND DRY PAPER
Aluminum Oxide Wet & Dry Paper gives you exceptionally long life with increased cutting power. Use before buffing compound to remove deep scratches, sand casting marks and more. Order by the individual sheet, or by the 100 sheet pack.
3 Reviews Hide Reviews Show Reviews
better than 3M
Though sand paper was sand paper but this last siginficantly longer than 3M. leaves a nice even finish too.
Great value
wonderful wet/dry abrasive for wood work
Great Product
I purchased this sandpaper in multiple grits to sand down the finish on a guitar neck. The sheets are very large and provided a lot of strips for my purposes.
