60 GRIT WET AND DRY PAPER
Silicon Carbide Wet & Dry Paper gives you exceptionally long life with increased cutting power. Use before buffing compound to remove deep scratches, sand casting marks and more. Order packs of 100 to save!
Excellent purchasing experience.
As always, great prices... prompt shipment... quality products. Will definitely order from again.
