null
Get Our Booklet
Buffing Wheels
See all of our buffing wheel products here
Unsure how to use these wheels - read our FREE How To Buff and Polish Booklet now.
  • 32 PLY CUSHION BUFF - 6 Inch
    These buffs are sewn with two rows to slightly stiffen the buff. This improves the speed of the final coloring operation, giving you performance somewhere between a spiral sewn and a loose wheel.
    $14.94
    Out of stock
  • CANTON FLANNEL WHEEL - 10" X 1/2"
    Canton Flannel is very soft, and this wheel is loosely stitched, so the layers of cloth flare out to give a wide angle ultra smooth polishing surface. Generally used with the BLUE or RED compound, this wheel can be used on the most delicate items such as...
    $8.79
    Choose Options
  • CANTON FLANNEL WHEEL 6 X 1/2
    $4.94
    Choose Options
  • CANTON FLANNEL WHEEL 8 X 1/2
    $7.14
    Choose Options
  • DENIM BUFFING WHEEL - 8" x 1/2"
    Our newest buffing wheel, the denim buffing wheel, is soft enough for any buffing application that calls for cotton wheels, but, because of the sturdy denim construction, it lasts much, much longer than a cotton buff. The faces of these wheels are...
    $12.09
    Out of stock
  • DOMET FLANNEL WHEEL - 4" X 1/2"
    Domet flannel is very the softest available material, and this wheel is loosely stitched, so the layers of cloth flare out to give a wide angle ultra smooth polishing surface. Generally used with the BLUE or RED compound, this wheel can be used on the...
    $3.84
    Choose Options
  • DOMET FLANNEL WHEEL - 6" X 1/2"
    $4.94
    Choose Options
  • DOMET FLANNEL WHEEL - 8" X 1/2"
    $6.04
    Out of stock
  • FELT WHEEL - HARD 6 X 1
    Ideal for many uses including woodworking, gunsmithing, knife sharpening, jewelry work etc. These firm felt wheels won't splay out or fray, making them ideal for the applications above. Long lasting and quick working. Use with white compound for most...
    $36.29
    Out of stock
  • FELT WHEEL - MEDIUM 6 X 1
    $30.24
    Add to Cart
  • LOOSE COTTON WHEEL 10 X 1/2
    Use with any compound to cut or color your metal. Gets into cracks and crevices better than Spiral Sewn Cotton Wheels. Buffing Compound Aluminum Polishing Kit Spiral Sewn Cotton Wheel Wheel Rake Free How To Buff and Polish Booklet Buffing Wheel &...
    $14.99
    Choose Options
  • LOOSE COTTON WHEEL 4 X 1/2
    $4.94
    Choose Options
  • LOOSE COTTON WHEEL 6 X 1/2
    $7.69
    Choose Options
  • LOOSE COTTON WHEEL 8 X 1/2
    $14.94
    Choose Options
  • NYLON BRISTLE BRUSH 6"
    The next best thing to a sand blaster! Lasts up to 10 times the life of a wire wheel! Will not puncture skin Does not shed bristles - unlike dangerous wire wheels Will not rust and maintains its shape Ideal for: Scratch brushing aluminum and other...
    $13.90
    Out of stock
