DENIM BUFFING WHEEL - 8" x 1/2"
Our newest buffing wheel, the denim buffing wheel, is soft enough for any buffing application that calls for cotton wheels, but, because of the sturdy denim construction, it lasts much, much longer than a cotton buff. The faces of these wheels are pre-raked to accept compound immediately. Use With Any Compound
Excellent product
Excellent service
Excellant product
Good results on both aluminum and SS.
