Canton Flannel is very soft, and this wheel is loosely stitched, so the layers of cloth flare out to give a wide angle ultra smooth polishing surface. Generally used with the BLUE or RED compound, this wheel can be used on the most delicate items such as silver and gold plate. This wheel should not be contaminated with any other compound.
4 Reviews Hide Reviews Show Reviews
                These are favored by many pen turnersMany pen turners recommend these buffs for finishing.
                Very durableThese are holding up better than expected. Good ability to push the piece into the wheels and get into the contours.
                Very softExactly what I wanted
                Great Polishing WHeelsI needed a very soft wheel for polishing brass blades from antique fans. This wheel does the job very well. No wheel scratches when using rouge.
