Canton Flannel is very soft, and this wheel is loosely stitched, so the layers of cloth flare out to give a wide angle ultra smooth polishing surface. Generally used with the BLUE or RED compound, this wheel can be used on the most delicate items such as silver and gold plate. This wheel should not be contaminated with any other compound.
7 Reviews Hide Reviews Show Reviews
                Plastic pen polishingThis is a great wheel for finishing small plastic parts such as for pen turning. It was recommended to me a few years ago and it took my finishes to a new level. With practice you learn how to cut your time down, but I'm glad I found these!
                ExcellentExcellent for cutting with compounds
                Final StepThese wheels are perfect for a deep gloss on your final step of polishing..
                6" flannel buff wheelsGreat quality backed by super fast shipping.
                Great wheel!Great soft buffing wheel! I use the buffing compound for acrylic and it's great!
                Does the job well!Works well woth Plastic buffing compound p-112 and PlASTIC -GLO 22
                works greatWorks with the blue buffing compound to put a glass like finish on my turnings.
