The next best thing to a sand blaster! Lasts up to 10 times the life of a wire wheel! Will not puncture skin Does not shed bristles - unlike dangerous wire wheels Will not rust and maintains its shape
Ideal for:
Scratch brushing aluminum and other metals for decorative finishes
Removes paint, corrosion, weld scale, rust & weld marks from steel
Gently removes paint and varnish from wood.
Sands wooden moldings, railings, turnings and banisters
Removes cement from tiles, stone and brick mortar
Prepares fiberglass, rubber, and all plastics for adhesive application
Frosts glass
1 Inch Arbor Hole
![This product can ship air and worldwide This product can ship air and worldwide](/content/images/airok.png)
Overall very good.
I work for a company that produces stainless steel grab bars and restroom accessories. These brushes work better and last longer than the Weiller brushes we were using. The Weiler brushes were expensive and didn't last long. But these brushes last longer than the Weilers and do an excellent job. My only complaint would be about the arbor size...We need a 2" arbor hole, but we have adapted the brushes so they will work for us.
very good
this thing works better that I thought it wood. Removes plate easily, gets rid of that "orange peel" effect from deplating, and de-burrs great!
