Quick view Caswell sku: TB2 TAPERED BUFF MSRP: Now: $11.54 Add to Cart Compare Quick view Caswell sku: RZ6 TREATED RAZOR BUFF - 6" MSRP: Now: $4.94 Add to Cart Compare Quick view Caswell sku: RZ8 TREATED RAZOR BUFF - 8" MSRP: Now: $6.04 Add to Cart Compare Quick view Caswell sku: DC10 TREATED SPIRAL SEWN BUFFING WHEEL - 10 MSRP: Now: $20.99 Out of stock Compare Quick view Caswell sku: DC4 TREATED SPIRAL SEWN BUFFING WHEEL - 4 MSRP: Now: $9.99 Choose Options Compare Quick view Caswell sku: DC6 TREATED SPIRAL SEWN BUFFING WHEEL - 6 MSRP: Now: $9.89 Choose Options Compare Quick view Caswell sku: DC8 TREATED SPIRAL SEWN BUFFING WHEEL - 8 MSRP: Now: $16.99 Out of stock Compare Quick view Caswell sku: BC10 TREATED VENTED BUFFING WHEEL - 10 MSRP: Now: $13.74 Out of stock Compare Quick view Caswell sku: BC4 TREATED VENTED BUFFING WHEEL - 4 MSRP: Now: $8.79 Choose Options Compare Quick view Caswell sku: BC6 TREATED VENTED BUFFING WHEEL - 6" X 1/2" MSRP: Now: $9.89 Choose Options Compare Quick view Caswell sku: BC8 TREATED VENTED BUFFING WHEEL - 8 MSRP: Now: $12.09 Choose Options Compare Quick view Caswell sku: VC10 UNTREATED VENTED BUFFING WHEEL - 10 MSRP: Now: $14.84 Choose Options Compare Quick view Caswell sku: VC6 UNTREATED VENTED BUFFING WHEEL - 6 MSRP: Now: $8.79 Add to Cart Compare Quick view Caswell sku: VC8 UNTREATED VENTED BUFFING WHEEL - 8 MSRP: Now: $12.09 Out of stock Compare Quick view TAPERED BUFF 2" Diameter x 2" Long 1/4" Shaft MSRP: Now: $11.54 Add to Cart Compare Quick view TREATED RAZOR BUFF - 6" 1/8" thick treated, razor buffs are perfect for getting into tight work areas and between fins on cylinder heads. The treated material is tough, long lasting and flexible. Use with a cutting compound. Buffs feature leather reinforced centers, with half... MSRP: Now: $4.94 Add to Cart Compare Quick view TREATED RAZOR BUFF - 8" 1/8" thick treated, razor buffs are perfect for getting into tight work areas and between fins on cylinder heads. The treated material is tough, long lasting and flexible. Use with a cutting compound. Buffs feature leather reinforced centers, with... MSRP: Now: $6.04 Add to Cart Compare Quick view TREATED SPIRAL SEWN BUFFING WHEEL - 10 These buffs are specially treated to give longer life than standard buffs. This treatment makes them much harder than regular cotton buffs, which allows the user to exert more pressure onto the wheel and gets the job done faster. Use with any compound... MSRP: Now: $20.99 Out of stock Compare Quick view TREATED SPIRAL SEWN BUFFING WHEEL - 4 These buffs are specially treated to give longer life than standard buffs. This treatment makes them much harder than regular cotton buffs, which allows the user to exert more pressure onto the wheel and gets the job done faster. Use with any compound... MSRP: Now: $9.99 Choose Options Compare Quick view TREATED SPIRAL SEWN BUFFING WHEEL - 6 These buffs are specially treated to give longer life than standard buffs. This treatment makes them much harder than regular cotton buffs, which allows the user to exert more pressure onto the wheel and gets the job done faster. Use with any compound... MSRP: Now: $9.89 Choose Options Compare Quick view TREATED SPIRAL SEWN BUFFING WHEEL - 8 These buffs are specially treated to give longer life than standard buffs. This treatment makes them much harder than regular cotton buffs, which allows the user to exert more pressure onto the wheel and gets the job done faster. Use with any compound... MSRP: Now: $16.99 Out of stock Compare Quick view TREATED VENTED BUFFING WHEEL - 10 These buffs are specially treated to give longer life than standard buffs. They cut and color faster and are vented to keep the workpiece cooler. Hard center allows fast mounting to tapered spindel for quick change. Use with any compound. MSRP: Now: $13.74 Out of stock Compare Quick view TREATED VENTED BUFFING WHEEL - 4 These buffs are specially treated to give longer life than standard buffs. They cut and color faster and are vented to keep the workpiece cooler. Hard center allows fast mounting to tapered spindel for quick change. Use with any compound. MSRP: Now: $8.79 Choose Options Compare Quick view TREATED VENTED BUFFING WHEEL - 6" X 1/2" These buffs are specially treated to give longer life than standard buffs. They cut and color faster and are vented to keep the workpiece cooler. Hard center allows fast mounting to tapered spindel for quick change. Use with any compound. MSRP: Now: $9.89 Choose Options Compare Quick view TREATED VENTED BUFFING WHEEL - 8 These buffs are specially treated to give longer life than standard buffs. They cut and color faster and are vented to keep the workpiece cooler. Hard center allows fast mounting to tapered spindel for quick change. Use with any compound. MSRP: Now: $12.09 Choose Options Compare Quick view UNTREATED VENTED BUFFING WHEEL - 10 The folded pleats hold more compound and keep the part cooler, resulting in a being twice as fast as a Spiral Sewn wheel. 10" wheels require 3" washers. These wheels are softer than their yellow cousins. MSRP: Now: $14.84 Choose Options Compare Quick view UNTREATED VENTED BUFFING WHEEL - 6 The folded pleats hold more compound and keep the part cooler, resulting in a being twice as fast as a Spiral Sewn wheel. 10" wheels require 3" washers. These wheels are softer than their yellow cousins. MSRP: Now: $8.79 Add to Cart Compare Quick view UNTREATED VENTED BUFFING WHEEL - 8 The folded pleats hold more compound and keep the part cooler, resulting in a being twice as fast as a Spiral Sewn wheel. 10" wheels require 3" washers. These wheels are softer than their yellow cousins. MSRP: Now: $12.09 Out of stock Compare Previous 1 2 3 4 Previous 1 2 3 4 Compare Selected × OK
