null
Get Our Booklet
Buffing Wheels
See all of our buffing wheel products here
Unsure how to use these wheels - read our FREE How To Buff and Polish Booklet now.
  • TREATED RAZOR BUFF - 6"
    1/8" thick treated, razor buffs are perfect for getting into tight work areas and between fins on cylinder heads. The treated material is tough, long lasting and flexible. Use with a cutting compound. Buffs feature leather reinforced centers, with half...
    $4.94
    Add to Cart
  • TREATED RAZOR BUFF - 8"
    1/8" thick treated, razor buffs are perfect for getting into tight work areas and between fins on cylinder heads. The treated material is tough, long lasting and flexible. Use with a cutting compound. Buffs feature leather reinforced centers, with...
    $6.04
    Add to Cart
  • TREATED SPIRAL SEWN BUFFING WHEEL - 10
    These buffs are specially treated to give longer life than standard buffs. This treatment makes them much harder than regular cotton buffs, which allows the user to exert more pressure onto the wheel and gets the job done faster. Use with any compound...
    $20.99
    Out of stock
  • TREATED SPIRAL SEWN BUFFING WHEEL - 4
    $9.99
    Choose Options
  • TREATED SPIRAL SEWN BUFFING WHEEL - 6
    $9.89
    Choose Options
  • TREATED SPIRAL SEWN BUFFING WHEEL - 8
    $16.99
    Out of stock
  • TREATED VENTED BUFFING WHEEL - 10
    These buffs are specially treated to give longer life than standard buffs. They cut and color faster and are vented to keep the workpiece cooler. Hard center allows fast mounting to tapered spindel for quick change. Use with any compound.
    $13.74
    Out of stock
  • TREATED VENTED BUFFING WHEEL - 4
    $8.79
    Choose Options
  • TREATED VENTED BUFFING WHEEL - 6" X 1/2"
    $9.89
    Choose Options
  • TREATED VENTED BUFFING WHEEL - 8
    $12.09
    Choose Options
  • UNTREATED VENTED BUFFING WHEEL - 6
    The folded pleats hold more compound and keep the part cooler, resulting in a being twice as fast as a Spiral Sewn wheel. 10" wheels require 3" washers. These wheels are softer than their yellow cousins.
    $8.79
    Add to Cart
  • UNTREATED VENTED BUFFING WHEEL - 8
    $12.09
    Out of stock
