Large Buffing Compound Starter Pack
Our buffing and polishing compounds are manufactured from high quality ingredients, designed for the industrial plater/polisher to obtain fast exceptional quality finishes.
The Jumbo bars are approximately 2" x 2" x 8" & weigh approx. 3 lb. each. The large bars are 1.25" x 1.25" x 6" and weigh approx. 1.5 lb. each.
We believe these industrial size bars represent a better value than the packaged tubes being marketed.
5 Reviews Hide Reviews Show Reviews
Good product
As described
Quality compound
Nice even consistancy! I've used other brands and have had inconsistant chunks of abrasive. Not the case with this stuff.
Excellent value.
One would really have to do a lot of buffing to wear out this amunt of compound. They work very well.
Perfect starter pack
Kit gives you compounds every material, the color coding makes compound identification and reorder a breeze.
Great bulk Idea and Great Products
I picked this up to add to my newly started metal workshop and was really happy this was put together in a pack. This made it super easy to order and stay organized as it is all in one place! The compound itself is awesome as well, it applies to the wheels really well and does what it is supposed to do. I will definitely keep ordering this pack or the Jumbo in the future!
