null
Additional Items Required
Get Our Plating Manual
Plating Kits
  • 24K Gold Tank Plating Kit - 2 Gal
    24ct Gold Tank Plating Kits Work safely with cyanide free gold to plate jewelry, flatware, baby shoes, flowers, bathroom fittings and much more.  Caswell 24ct Gold is ideal for immersion plating of larger items. For brush plating...
    $1,450.89
    Add to Cart
  • 5 AMP CC RECTIFIER
    5 Amp Constant Current Rectifier Ideal for small anodizing runs, small plating jobs. Will anodize parts up to 1 sq ft. Will nickel & copper plate parts up to 70 sq in.   Other options: Wamptek Dr Meter Hanmatek
    $213.40
    Add to Cart
  • Aluminum Degreaser Powder - 2lb Makes 3 Gallons
    This special degreaser for Aluminum quickly cleans any aluminum alloy without etching. Mix 2 lbs of cleaner with 3 gallons of distilled water in a stainless steel container. Heat to 130 deg F on a hotplate. Immerse aluminum parts for 3-10 minutes prior...
    $30.24
    Add to Cart
  • Black Krome Plating Kit - 1 Gal Black Krome Plating Kit - 1 Gal
    Black Krome™ Kit This spectacular product will add style and elegance to many products. Safe to use. Contains no chrome or nickel. Ideal for vehicle trim, guns, musical instruments, fishing lures, etc. The system plates within a couple of minutes over a...
    $150.69
    Add to Cart
  • Black Krome Plating Kit - 2 Gal Black Krome Plating Kit - 2 Gal
    $279.39
    Add to Cart
  • Black Krome Plating Kit - 4 Gal Black Krome Plating Kit - 4 Gal
    $386.64
    Add to Cart
  • Black Nickel Plating Kit - 1.5 Gallon Black Nickel Plating Kit - 1.5 Gallon
    Black Nickel Plating Kit This kit gives a beautiful translucent Black Nickel coating over most metals including nickel, copper, brass, tin, steel, stainless steel and zinc. Mix up the chemicals with distilled water, clean your parts with the included...
    $240.89
    Add to Cart
  • BLUE CHROMATE CONCENTRATE - 1 QT
    BLUE CHROMATE Our blue chromate concentrate produces a true blue conversion coating on zinc plated items. It is a single dip blue trivalent chromate that offers high salt spray resistance for up to 130 hours to white rust corrosion, and 160-200 hours to...
    $72.59
    Add to Cart
  • BLUE CHROMATE CONCENTRATE - 8OZ BLUE CHROMATE CONCENTRATE - 8OZ
    $25.29
    Add to Cart
  • Brass Plating Kit - 1 Gallon
    Brass Plating Kits Caswell Brass Plating Solution is a unique cyanide-free alkaline brass plating system which plates a true 70/30 yellow-green plate directly onto steel and bright nickel plated surfaces. It can be used for heavy brass plating which will...
    $236.49
    Add to Cart
  • Brass Plating Kit - 2 Gallon Brass Plating Kit - 2 Gallon
    $379.49
    Add to Cart
  • Bright Acid Copper Plating Kit - 1.5 Gal
    Bright Acid Copper Plating Kit Our new and improved copper plating system now gives constant bright copper plating, that requires little to no polishing after plating. For the restorer, copper plating must be one of the most useful repair tools there is...
    $204.59
    Add to Cart
