BLUE CHROMATE
Our blue chromate concentrate produces a true blue conversion coating on zinc plated items. It is a single dip blue trivalent chromate that offers high salt spray resistance for up to 130 hours to white rust corrosion, and 160-200 hours to red rust corrosion. No additional topcoat is required to obtain this high degree of corrosion resistance. It produces a beautiful blue/clear trivalent chromate to meet automotive and all other industrial standards.
Dip zinc plated parts at room temperature for 15-40 seconds. For best results, dry with hot air (150 deg F)
Mix 1 part Blue Chromate to 4 parts Distilled Water, ie. 1 Quart Makes 1.25 Gallon Mixed
Hazardous Shipping Info
GHS Info
SDS
4 Reviews Hide Reviews Show Reviews
Great product, great price!
I'm using this with the Copy Cad & Zinc plating setup. It imparts a nice clear blue color (almost iridescent) that looks great.This is a bit more forgiving than the yellow chromate for a beginner. Like everything with plating, prep is the key to getting a good end result.
awesome products! I always have the best looking finishes when using your products!
awesome
Great for automotive restoration aapplicatios.
Great product
Provided the professional results that I needed
