null
Additional Items Required
Get Our Plating Manual
Plating Kits
  • Baby Shoe Bronzing Kit For Export Baby Shoe Bronzing Kit For Export
    Now you can join the thousands of people that are bronzing baby shoes and similar objects, as a hobby or as a business, with our new Baby Shoe Bronzing Kits, and not worry about the shipping expense of hazardous materials. We put together this kit for...
    $507.09
    Add to Cart
  • Barrel Plater - 4" x 4" Barrel Plater - 4" x 4"
    These miniature barrel platers are perfect for plating batches of small parts in any of our plating kits. We recommend our 4.5 Gallon size kits for barrel plating use. Simply add your parts, submerge the barrel and turn on power to the barrel and...
    $1,699.00
    Choose Options
  • Black Chromate Concentrate - 8 oz makes 1 Gal Black Chromate Concentrate - 8 oz makes 1 Gal
    BLACK CHROMATE Our Black Chromate concentrate provide a true black chromate on zinc or cadmium plated parts. It is especially effective for chromating bolt parts such as nuts, bolts and various fasteners. Immerse plated parts for 15-40 seconds, depending...
    $36.29
    Add to Cart
  • Black Krome Plating Kit - 1 Gal Black Krome Plating Kit - 1 Gal
    Black Krome™ Kit This spectacular product will add style and elegance to many products. Safe to use. Contains no chrome or nickel. Ideal for vehicle trim, guns, musical instruments, fishing lures, etc. The system plates within a couple of minutes over a...
    $150.69
    Add to Cart
  • Black Krome Plating Kit - 2 Gal Black Krome Plating Kit - 2 Gal
    $279.39
    Add to Cart
  • Black Krome Plating Kit - 4 Gal Black Krome Plating Kit - 4 Gal
    $386.64
    Add to Cart
  • Black Nickel Plating Kit - 1.5 Gallon Black Nickel Plating Kit - 1.5 Gallon
    Black Nickel Plating Kit This kit gives a beautiful translucent Black Nickel coating over most metals including nickel, copper, brass, tin, steel, stainless steel and zinc. Mix up the chemicals with distilled water, clean your parts with the included...
    $240.89
    Add to Cart
  • Black Nickel Plating Kit - 15 Gallon Black Nickel Plating Kit - 15 Gallon
    $2,055.89
    Add to Cart
  • Black Nickel Plating Kit - 3 Gallon Black Nickel Plating Kit - 3 Gallon
    $301.39
    Add to Cart
  • Black Nickel Plating Kit - 4.5 Gallon Black Nickel Plating Kit - 4.5 Gallon
    $361.89
    Add to Cart
  • BLUE CHROMATE CONCENTRATE - 1 QT
    BLUE CHROMATE Our blue chromate concentrate produces a true blue conversion coating on zinc plated items. It is a single dip blue trivalent chromate that offers high salt spray resistance for up to 130 hours to white rust corrosion, and 160-200 hours to...
    $72.59
    Add to Cart
