Mix with 1.5 Gals Distilled Water To Make Black Nickel Plating Solution. Plate with a nickel anode at 0.01 amps per square inch.
GHS Info
SDS
Using Caswell’s Black Nickel Solution.
I had decent results considering it was my 1st time to Electro Bath Plate anything. I would have given the product a 4 or maybe even a 5 star rating but I took off a star due to the lack of help or support for its use. * I was lucky to find one (1) Single person who had used the Black Nickel Plating solution on YouTube & made a short instruction video for her project. THAT WAS IT…. **only needed a Liter of this stuff not 1.5 gallons. So I took off a star for not have a smaller unit package available for the product.
