ALUMINUM HIGH LUSTRE COMPOUND
A very dry grade intended for buffing small work to a high luster. Will not pack into
small cavities or recesses. If a brighter finish than No. A-14 Compound is desired,
re-buff using A-15.
2" X 2" X 10" Bar
4 Reviews Hide Reviews Show Reviews
realy dont know yet
haven't used it yet just a few more days till im ready. but will give it a 5 on the experience with the other compounds I have used
Works great
Vintage boat motor use this compound second and it's ready for final
Brilliant finish!
The lustre compound really does bring out a highly polished finish
Good
Great product
