BLACK MAGIC ROUGE
A favorite for finishing brass, aluminum, copper, tin plate and other alloys. Will bring out a mirror-like luster on the work. Being a medium greasy grade it is ideal for the all around buffing job, requiring a brilliant finish.
2" x 2" x 10" Bar
SDS
unknown
haven't got there yet again going by the quality of the other ones I've used
A good product, polishes well.
