COLORING COMPOUND (MED GREASY)
NON-FERROUS COLORING BAR COMPOUNDS
SOMETIMES REFERRED TO AS WHITE OR BLACK DIAMOND BUFFING COMPOUND.
Intended for buffing non-ferrous metals where the work surface is in good condition, free of deep tool or die marks. When heavy marks are present, Tripoli Buffing Compound is generally used to first cut down the surface and then a second buffing operation is performed using a "Coloring" Compound to produce a mirror-bright finish.
