A ready-to-use, water-soluble, synthetic adhesive for setting up polishing wheels and bobs made of cloth, canvas, felt, leather or wood. Apply by brushing on thin coats and rolling the wheel in a pan of loose abrasive grain. Multiple coats are recommended to build up long lasting abrasive head thickness. Allow coating to air dry. Drying time may be reduced by using a heat lamp or oven heat. May be thinned with water if a "sizing coat" is desired on new wheels.
