ALUMINUM CUT & COLORING COMPOUND
This grade was developed to "cut down" and "color" aluminum in one buffing operation on hand and automatic buffing machines. Brings up a high luster, leaving the buffed work clean and free of excess grease, or dirt.
2" X 2" X 10" Bar
5 Reviews Hide Reviews Show Reviews
Works great
Vintage boat motor, sand to 300, use this compound first, works great
Alu cut compound works well!
This with the treated spiral sewn wheels cuts the grooves from the aluminium cases I use for my products
Good
Great product
I highly recommend this company
Very satisfied. Fast shipping.
Great for aluminum
Seems to do a good job with aluminum. Although I would still use black emery before this step.
