Our newest buffing wheel, the denim buffing wheel, is soft enough for any buffing application that calls for cotton wheels, but, because of the sturdy denim construction, it lasts much, much longer than a cotton buff. The faces of these wheels are pre-raked to accept compound immediately. Use With Any Compound
6 Reviews Hide Reviews Show Reviews
Tough, tough, tough
A much stronger' stiffer wheel that lasts and lasts
good wheel
Initial loss of material, and now is doing a fine job
Excellent as Always...Thanks
Denim Buffs
I got these in the 6 in. size as the 8 inch were not available at the time of the order. I used these extensively on my Al swingarm and they worked...very well...I recommend these...and I may pick up some 10 inch down the road.
Great product
Will buy this again
excelent buffing
The Denim Buffing Wheel, with grit from black to white is an excellent polishing product. Last longer. This product will always be on my bench
